power window switch
2005 HONDA ACCORD
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKES05
i need to replace the power window switch in the drivers door its a 2 door coupe. what is the best way to remove the door panel?
Dec 9, 2009 at 2:42 PM
HONDA TECH 1818
  • CAR REPAIR CONTRIBUTOR
  • 536 POSTS
You don't have to remove the door panel to replace the master switch. Check out the instructions in the diagrams below.
Dec 9, 2009 at 8:22 PM
SHANDRAS67
I just installed a new driver's side window switch. The windows work perfectly again - thank goodness. But my problem is that my key fob lock/unlock and trunk opener doesn't work. Do I need to reset something in the car to get the window switch to recognize my key fob? Help please.
Jul 31, 2019 at 1:49 PM (Merged)
FIXITMR
  • 9,990 POSTS
you got a manual to look up how to reprogram it?
SHANDRAS67
I have some experience with cars. But I will settle with Thank you for your advice. Unfortunately that is where I looked first and my "manual" does not give me advice on how to sync my key fob after installing a new switch. It only gives advice on how to reset the system after losing power (via a disconnected battery, etc.). So I am looking for some technical advice on how to sync the key fob with the car after installing a new main window switch. I am guessing that there is a special trick to reset the system that only a dealer would know. Anyone who has some sound advice on this - it would be greatly appreciated. Thanks.
FIXITMR
  • 9,990 POSTS
or try this.
Turn key on Hit lock button on fob
turn key off
turn key on hit lock button on fob
turn key off
turn key off
you should hear the door lock actuators work(you are in the programming mode)
hit lock buttons on both fobs you should hear the door actuators working with each button press.
Turn ign switch to off
Remove key and viola Whatever keyless remotes will work will work then.
You must do each step quickly for success. BTW most service advisors at dealerships will perform this operation free of charge. If you are not successful on the first attempt try again until it works.
  • 54,350 POSTS
The Window switch control module must be reset here are the instructions on how to replace the switch correctly and how to set it up. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
MLEMISE
Electrical problem
2003 Honda Accord 6 cyl Two Wheel Drive Automatic
I have confirmed that my driver's side power window switch on my 2003 accord 2-door EX coupe V6 is bad and needs to be replaced. Can you pls provide instructions on how to replace the switch? Do I need to remove the door panel, and if so, how?
Thanks
KHLOW2008
  • 41,814 POSTS
Hi mlemise, The switch is pluggged in and can be removed by carefully prying it out. Note the locking tabs position. Unplug the connectors ( A) after prying the switch out and it can be replaced.
https://images.2carpros.com/forum/automotive_pictures/192750_SwitchMaster03AccordFig11_1.jpg
MLEMISE
Thanks for the info, but this diagram is for a 4-door. Mine is the 2-door coupe, and the set-up is completely different
KHLOW2008
  • 41,814 POSTS
Sorry for the error. Here are the 2-door procedures. 2-DOOR Remove the power window switch panel (A). â—¦ -1 Insert a flat-tip screwdriver wrapped with protective tape through the hole under the armrest, and push up the bottom of the power window switch (B) to release the panel. â—¦ -2 Pull out along the edge of the panel to release the hook (C) and clips (D). â—¦ -3 Disconnect the power mirror switch connector (E) (driver's) and the power window switch connector (F).
https://images.2carpros.com/forum/automotive_pictures/192750_SwitchMaster03AccordFig09_1.jpg
LIKAN
i just changed the master window switch, and key remote does not recognice the new master switch is any way to make it work any codification or something to make it work with key remote
KHLOW2008
  • 41,814 POSTS
Hi likan,
Just managed to get some info on programming the remote control, but these are for Taiwan models so don't know if it works.
You can only program a maximum of 3 control.
All steps must be done within the specified time.
Ensure all doors are closed.
Step 1. Turn ignition switch to 'ON'
Step 2. In between 1 to 4 seconds, Press remote in direction of door sensor.
Step 3. In between 1 to 4 seconds. Turn ignition switch to 'OFF'
Step 4. In between 1 to 4 seconds, turn ignition to 'ON'
Step 5. In between 1 to 4 seconds, Press remote in direction of door sensor.
Step 6. In between 1 to 4 seconds. Turn ignition switch to 'OFF'
Step 7. In between 1 to 4 seconds, turn ignition to 'ON'
Step 8. In between 1 to 4 seconds, Press remote in direction of door sensor.
Step 9. In between 1 to 4 seconds. Turn ignition switch to 'OFF'
Step 10. In between 1 to 4 seconds, turn ignition to 'ON'
Step 11. In between 1 to 4 seconds, Press remote in direction of door sensor.
Step 12. Confirm doors are locking or unlocking.
Step 13. For programming spare remote control units, within 10 seconds, press them in direction of door sensor. Confirm that the doors are locking or unlocking when remote are activated.
Step 14. Turn ignition "OFF"
Step 15. Test and confirm if all remotes are working.
Hope this works.
HVLE
My battery die one day and I had it jumped from a friend and since that day my power window switch and power door lock stopped working. I can roll down my driver side windows but i cant roll down my passenger side(manually passenger side works).I also change my fuse under the hood and check the interior fuse..how do i fix this problem?
KHLOW2008
  • 41,814 POSTS
Hi hvle,
Seems the Multiplex System is causing the problem. you would need appropriate equipments to test/diagnose the problem.
JACKOFALLO
The power switch is giving problems. It has problem with the two front doors. It can lower the window down but would not work upwards.
I replaced the power switch and the problem was solved for a few days and recurred again.
What could be the issue? Please advis. Thanks in advance.
KHLOW2008
  • 41,814 POSTS
You have to check the electricals. Your new switches could also be the culprit. Check for current supply to the motors while operating the switches to determine if they are operating properly.
JACKOFALLO
I took out the power switch piece and cleaned the copper connec`toers with alcohol and it worked!
KHLOW2008
  • 41,814 POSTS
Cheers, you solved your problem
