Rear Defogger not working
2007 HONDA ACCORD
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
F
I have a 07 accord. the rear defogger does not work. fuses are ok checked by dealer. Also radio/ antenna reception is poor. Dealer appt. needed for troubleshooting thanks
Nov 14, 2010 at 4:50 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Check the relay in underhood relay block. Terminal # 2i spower supply from battery and should be hot at all times. Terminal # 1 is to the defogger. Use a fused jumper and bridge both terminals to test if the defoggger works.
Poor radio reception could be due to the antenna, its conneection or the radio itself.
Nov 14, 2010 at 6:05 PM
ADENNIS
rear defroster does not work. The push button indicator comes on suggesting that the heater should be working but it's not. I have an extended warranty with $100.00 deductible, should I take it in and have them repar this or is it just a loose connection some where.
I removed the plastic cover that is located at the top of the rear window and the single connector looks good--no corrosion. [could that be the antenea??] What else can I do? I would hate to pay a $100 just for a loose wire that I could fix. Thanks for your help :))
Jan 5, 2020 at 1:28 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Ther is a defogger relay behind the right side of the dash/behind the right fuse box cover. Try swapping this one for the a/c relay to see if it fixes it. Relays are under $100
CARLQUINET
Checked all fuses and replaced relay in dash. Still no rear defroster This is in 2002 Honda Accord Lx
  • 54,354 POSTS
It could be the thin film element in the glass. lets check for power and ground at the glass. here is a guide to help us and the defrost wiring diagrams so you can see how the system works:
Check out the diagrams (below). Please let us know what you find.
MEADWELL JENNIFER
I just went to use rear defroster - did not work-
heater blower console light all working ? what to do to what to look for
KHLOW2008
  • 41,814 POSTS
Hi MEADWELL JENNIFER,
You need to check
1. Fuse # 53 (40 A) underhood.
2. Rear defroster relay.
3. Rear defroster circuit.
BONNIE BRYANT
I have a 1997 Honda Accord, 4 cyl., automatic, 56,700 miles. The rear window defroster is not working. The front defrost, heater and blower are working OK. (I have noticed some bits of brownish foam coming from the front vents, however.) Is this a major repair or something I could possibly fix myself?
MERLIN2021
  • 17,250 POSTS
Brownish foam? You better check the radiator! What color is your antifreeze? If it's that brown foam, check the engine oil too! Get back with the results, this could be bad...
2CARPRO JACK
  • 11,533 POSTS
Sounds like the insulating foam that seals the vents to the plenum at the seams.No real big deal, just annoying. You can fix it with any thin foam
