Hi, I found your site by searching for a symptom I have with my 2001 accord (EX). It has what seems like a random miss/hesitation. If I am cruising or holding a steady speed usually between 2000 and 3000 rpm, and step into the throttle a bit, it will very often start to accelerate, then pause for up to a second, then finally pick up again. Other times during steady acceleration I can feel a slight missing as it revs up. Sometimes even with full throttle it does not respond for a few seconds.
This seems to be worst when the car has warmed up, when I start off in the morning it is very responsive, if I mash the gas in 1st gear it will spin the tires, but when warm it does not respond that sharply, it's more of a gradual ramp up in power.
I have replaced plugs, wires, dist. cap and rotor, and the o2 sensor. After doing that it was much better for a few days but now it is more or less back to the way it was.
You responded to another fellow with very similar symptoms in a 98 Accord by saying it sounded like the distributor and that that was a common thing (you used the term achilles heel) -- can you explain in more detail what you meant? Does that sound like it could be the problem in my case?
Thanks for any insight...
Apr 30, 2009 at 6:02 AM
