Driving down the road, Oil Light went on... 10 -15 seconds later car cut out... and I coasted to the side of the road... where I added a few Qrts of Oil and drove last 2 miles home. The cars water/oil belt broke, and the oil shaft ring popped out. I replaced belt and shaft ring.. and while I was there the timing belt... Now, the car turns over but does not start. If the timing belt is wrong, is there a switch that will prevent the car from starting? I have turned the crank shaft and watched all the parts move, there is spark from the wires, gas in the tank, but the car will not "ignite".
Thank you,
Miguel
Thank you,
Miguel
Dec 14, 2009 at 12:18 AM
