Cooling fans not working
2001 HONDA ACCORD
1 MILES
MONEYCOUNT
  • 27 POSTS
radiator fans are not coming on and just noticed that the coolant temperature sensor is broken. Fuses are not blown, not sure about fan relay though. Question is.....does the sensor operate the fans? Or could it be the relay or a short in the circuit somewhere? The fans do operate by jumping battery direct. Any help is greatly appreciated.
Feb 27, 2013 at 7:44 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Greetings
The coolant temperature sensor lets the fan's relay know when to open and close the circuite, so if the sensor is bad then it will not allow the fans to operate.
Feb 27, 2013 at 7:55 AM
MONEYCOUNT
  • 27 POSTS
Now on the 2001 Accord the coolant sensor is the broken sensor I have (which is on the side of the block) and not the sensor on thermostat housing correct?
Feb 27, 2013 at 8:25 AM
MONEYCOUNT
  • 27 POSTS
The one on the thermostat is to signal the gauge right?
Feb 27, 2013 at 8:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The sensor near the thermostat is for the temperature gauge, yes. The 2001 accord actually has a radiator fan switch, not a sensor (image below). Is this the part you are talking about being broken?
Feb 27, 2013 at 8:38 AM
MONEYCOUNT
  • 27 POSTS
The one that is broken according to the diagram is the Engine Coolant Temperature Sensor(ECT). So your saying that its the Radiator Fan Switch thats bad? Because where it shows the Coolant Temperature Gauge Sending Unit here I dont have that. There's just a plug there.
Feb 27, 2013 at 9:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yeah, the coolant temp gauge sending unit is only for the 98 and 99 models, the ECT sensor replaces that sending unit on your model so you will have the ECT sensor and the fan switch. The best place to start diagnosing a faulty fan would be fuses and the relay though as they are the cheapest and easiest to test. But since the ECT is bad on yours, that is most likely at fault.
Feb 27, 2013 at 7:40 PM
MONEYCOUNT
  • 27 POSTS
Ok, great. Im replacing the ECT now and hope thats it. The fuses and relay are fine. So if after replacing the ECT and fans still dont come on then its probably the fan switch correct? I'll keep ya posted. Thx
Feb 27, 2013 at 8:17 PM
MONEYCOUNT
  • 27 POSTS
The fan switch which is the one on top of the thermostat housing right?
Feb 27, 2013 at 8:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, that is correct. the switch is on top of the tstat housing as shown in the previous graphic. let me know how it goes.
Feb 27, 2013 at 8:24 PM
MONEYCOUNT
  • 27 POSTS
I sure will. And once again THANKS for all the advice! :)
Feb 27, 2013 at 8:27 PM
NEWYORKER52
I have 1999 Honda Accord with 123K miles. The radiator fan is not working properly; the fan motor goes on before the engine is on. I have noticed when the motor goes on and off a clicking noise is coming. I checked coolant level which is OK. I have tried a new relay but this did not fix the problem. Do you have any suggestions? I am hoping this is something minor and a simple fix. Thanks for any help you may have for me.
Jun 3, 2019 at 6:12 PM (Merged)
FISHERMAN
  • 937 POSTS
[quote:7c8845b3c7="newyorker52"]Other Category problem
1999 Honda Accord 4 cyl Front Wheel Drive Automatic 123000 miles
I have 1999 Honda Accord with 123K miles. The radiator fan is not working properly; the fan motor goes on before the engine is on. I have noticed when the motor goes on and off a clicking noise is coming. I checked coolant level which is OK. I have tried a new relay but this did not fix the problem. Do you have any suggestions? I am hoping this is something minor and a simple fix. Thanks for any help you may have for me.[/quote:7c8845b3c7]
Hello !!
Check the thermo-switch (radiator fan switch)( that switch turn on and off the cooling fan as soon as the temperature reaches the specific temperature in this case:196-203 degrees F.)
good luck!
FISHERMAN
  • 937 POSTS
Hello Again..
The radiator fan switch its located on thermostat housing.
If you need the wiring schematic just let me know!
good Luck!
2CP-ARCHIVES
  • 4,540 POSTS
1999 Honda Accord mileage 85,000. Today when I was driving to work I had the A/C on. After a while of being stuck in traffic I turned off the A/C since it was really cold inside the car. After five minutes of stop and go traffic, I looked down to my board and saw the temperature needle rising tours the hot area. I immediately stopped and opened the hood. I noticed that for some reason the cooling fan were not working. I went back to the car and shot off the engine. As soon as I took the key out the cooling fan started working. Then I put the car in switch and the cooling fan stopped working again. I waited for the car to cool off and then I started the car and turn on the A/C. After this, both of the cooling fans started working. I turned off the A/C and left the car running. After three minutes the car started overheating again and I repeated the same operation. Turn on the AC/ and the fans started working. I turned off the AC and left the car running and it started overheating again. The cooling fans at no point came on. I then turned off the car and the fan started working. I checked the cooling fan fuse and it's okay. I checked the cooling fan relay under the hood since I have had the same exact problem with an 1989 Accord LX-I I had own previously and it ended up being the cooling fan relay. The power window relay and the cooling fan are exactly the same. I swapped relays just to se if the problem could off been the relay but not even with the relay swap the fans worked. After I swap the relays I started the car again and let it run and it started overheating again. I put the relays back where they belonged and just drove off to work with the A/C on.
2CP-ARCHIVES
  • 4,540 POSTS
You probably have a temperature sensor that has failed. This can be verified by scanning the computer.
THEDA
I just purchased a 94 Honda accord and the A/C is not working and I seen there was no coolant so I went and got coolant put it in and and then noticed the fans are not going . I don't know much about cars. What could it be?
KHLOW2008
  • 41,814 POSTS
The cooling fans do not work upon starting vehicle. They only work when a certain temperature is reached and that triggers the cooling fan switch to activate the cooling fan relays and cooling fans.
IGGY1969
Recently my car overheated,then I changed the thermostat and it runs great,it does not overheat anymore but the cooling fans do not turn on.I also tested the fans motors directly from the battery and they do work,also checked the fuses and they're fine ,so I think it could be either the fan switch or the cooling fan control.What can you tell me?
Could be the engine coolant temperature sensor/relay and computer controlled of the relay
IGGY1969
I've checked the relays under the hood behind the glove box, switching the power windows relay with the fan relay, they seem fine.
What about the rest I've mentioned ? Are they good to go
IGGY1969
How do I test them?
DERRICKROSS8
i have a 1990 honda accord with 275,000 miles. there are 2 cooling fans and niether of them will turn on. for about a week the one that runs while the motor is on would not turn on but as soon as i shut the car off the other one would kick on. now they both wont turn on. help!! what could this be???
BRUCE HUNT
  • 3,754 POSTS
Try the a/c, when you turn it on the fan should run on the A/C coolant radiator. If it does not, then try not wiring the fan straight to the battery. If it runs, the sensor is bad. Same story with the radiator on the cooling system.
Do you know how to use a scantool and a DVOM ? If not bring it in-
GLUNGER
I am having a very similar problem with my 98 honda civic, 117,000 miles. I noticed the temp guage moving erratically and when I turned on the heat, it would go back to its normal temp. Then I noticed that the fans were not turning on at all. I got in an accident about a month ago, with some mild to moderate damage to the front center, and it has since been repaired. Could the shop have missed something, or is it just a problem with the fan?
BRUCE HUNT
  • 3,754 POSTS
If the fans do not come on, hook them straight to the battery to test them. If they run then the sensor is faulty or the fuse is bad.
TEDOTDOE
Ok guys I'm having the same problem on my 1991 Pontiac grand am and my temperature gauge jumps so much also but i noticed that my fan doesn't turn on either but how would i be able to hook it straight up to the battery.
