Periodically this car simply will not start (turn over). The battery is fine - radio, lights etc. all work fine, but turning the key to start the car, there is nothing - no clicking of the starter - simply nothing. I try pulling the car into Drive and then putting it back into park to determine if maybe that switch is failing but still nothing. To solve this problem, if we simply jump it quickly (so I know were not charging the battery at all), the car will start immediately. I can then turn it of and restart it repeatedly. It'll then run fine for days, weeks, or months without having the problem - but the problem will ultimately return. I beleive we've put a new starter and a new ignition switch into the vehicle. What could be causing this type of problem which seems to totally go away for some period by simply jumping the car?
Jul 13, 2010 at 1:25 PM
