1997 Honda Accord 2.2 L 4cyl. Basically it takes me several attempts to turn over the car (crank). The battery is OK. Not sure about the wirings as i'm not an expert in identifying which leads to where. After the car has started and the engine is hot and when i turn off the ignition and attempt to crank the car again from starting position it works immediately. So it only happens when the engine is not warm. I may suspect i may have held on the ignition (to crank the engine) for to too long about 5 seconds after the engine has been turned over when this problem first arose. Any ideas as to the solution?
Dec 13, 2008 at 8:00 PM
