replace the oil pan
2005 HONDA ACCORD
4 CYL • FWD • AUTOMATIC
TRAVIS882000
how do you replace an oil pan in a 2005 honda accord 2.4
Jul 3, 2011 at 8:53 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
Hey TRAVIS,
You must support the engine becasue the cross member must be removed, also they glue the hack out of those oil pans so they make a tool that will cut the seal. Here are instructions and some diagrams so you can see what it going on.
Oil Pan Removal
1. Drain the engine oil.
2. Make sure you have the anti-theft codes for the radio and navigation system, then write down the frequencies for the radio's preset buttons.
3. Disconnect the negative cable from the battery first, then disconnect the positive cable. Remove the battery.
4. Remove the air cleaner housing.
5. Remove the harness clamp. Remove the two bolts, and loosen the two bolts securing the battery base, then remove the battery base.
6. Remove the clutch slave cylinder, and clutch line bracket mounting bolt (M/T).
7. Remove the ground cable, then remove the transmission upper mount/bracket assembly.
8. Remove the front mount stop, then remove the front mount bolt.
9. Remove the rear mount stop, then remove the rear mount bolt.
10. Raise the vehicle on the hoist to full height or on jack stands.
11. Remove the front tires/wheels.
12. Disconnect the stabilizer links.
13. Remove the left side damper fork.
14. Disconnect the left side suspension lower arm ball joint.
16. Remove the left side driveshaft. Coat all precision-finished surfaces with clean engine oil. Tie plastic bag over the driveshaft end.
17. Remove the nuts securing the transmission lower front mount and transmission lower rear mount.
18. Use a transmission jack or floor jack to lift the transmission 40 - 55 mm (1.6 - 2.2 inch).
19. Remove the stiffener.
20. Remove the bolts/nuts securing the oil pan.
21. Drive an oil pan seal cutter between the oil pan and engine block.
22. Cut the oil pan seal by striking the side of the cutter to slide the cutter along the oil pan.
23. Remove the oil pan.
Please let us know happens so it will help others.
Best, Ken
Dec 8, 2016 at 12:51 PM
DRIVEWAYMECHANIC
Engine Mechanical problem
1998 Honda Accord 6 cyl Front Wheel Drive Automatic 175000 miles
I have a 98 honda accord v6 needing a new oil pan. I just bought the oil pan and wonder if the exhaust and cross member need to be removed to remove and install?
Dec 8, 2016 at 12:52 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi drivewaymechanic,
The exhaust from the manifold to the catalytic converter needs to be remove.
Any other things directly under the oil pan has to go so that when installing you would be able to gain easy eccess.
TJWSR
1997 Honda Accord 4 cyl Front Wheel Drive Automatic 197000 miles
my mechanic says oil pan needs replacing.
My skills are mid-level, have tools, can replace external parts, do own oil changes, brakes, exhaust, etc.
Can a skilled diy-er do this job? Any potenetial big problems or it this a straight, buy a new pan and gasket, remove the screws, clean the gasket area, install the new gasket, torque the bolts (? lbs. tq.)?
I figure 2 hours if all goes well.
KHLOW2008
  • 41,814 POSTS
Hi TJWsr, You got it right. However the exhaust from manifold lower end to catalytic converter has to be removed to facilitate replacement. Bolts torqued at 10 lbs.
https://images.2carpros.com/forum/automotive_pictures/192750_OilPan97Accord_1.jpg
DEEDEEBRT
1994 Honda Accord 4 cyl Two Wheel Drive Automatic 131,00 miles
How long does it take to change the oil pan on a 1994 Honda Accord XE and does the exhaust pipe have to be dropped?
Dec 8, 2016 at 12:53 PM (Merged)
ROB2008
  • 258 POSTS
Hi, It will probably take up to a three to four hours if the person has been aroun cars for awhile .. see the info on your car . I hope this helps you . REMOVAL & INSTALLATION See Figures 1, 2, 3, 4, 5, 6 and 7 CAUTION The EPA warns that prolonged contact with used engine oil may cause a number of skin disorders, including cancer! You should make every effort to minimize your exposure to used engine oil. Protective gloves should be worn when changing the oil. Wash your hands and any other exposed skin areas as soon as possible after exposure to used engine oil. Soap and water, or waterless hand cleaner should be used. Disconnect the negative battery cable. Firmly apply the parking brake and block the rear wheels. Raise and support the front of the vehicle on jackstands. Drain the engine oil. If necessary for additional clearance, remove the center beam. Fig. 1: On most models, it will be necessary to remove the center beam to access the oil pan Disconnect the exhaust pipe from the exhaust manifold(s), then position it aside or remove it from the vehicle. Fig. 2: After disconnecting the exhaust pipe from the manifold, the bracket securing the pipe to the engine block should be removed. The pipe can now be positioned aside If equipped with flywheel dust shield, it may be necessary to remove it for access. Fig. 3: The dust shield is secured by several small bolts Fig. 4: The dust shield may require some maneuvering to remove. Be careful not to damage it If equipped, disconnect the breather hose from the oil pan. Fig. 5: If equipped, the breather hose must be disconnected from the oil pan
https://images.2carpros.com/forum/automotive_pictures/181498_pic1_3.jpg
Fig. 6: After its attaching bolts are removed, the oil pan can be removed from the engine. Never pry on the pan to get it loose Remove and discard the old gasket.
https://images.2carpros.com/forum/automotive_pictures/181498_pic2_1.jpg
Fig. 7: The gasket must always be replaced To install:
https://images.2carpros.com/forum/automotive_pictures/181498_pic3_4.jpg
8.If equipped, disconnect the breather hose from the oil pan.
https://images.2carpros.com/forum/automotive_pictures/181498_pic4_3.jpg
https://images.2carpros.com/forum/automotive_pictures/181498_pic_5_2.jpg
9.[Remove the oil pan nuts/bolts (in a crisscross pattern) and the oil pan. If necessary, use a mallet to tap the corners of the oil pan. DO NOT pry on the pan to get it loose. img] 10.Remove and discard the old gasket.
https://images.2carpros.com/forum/automotive_pictures/181498_pic6_2.jpg
