1987 Honda Accord Power Windows
1987 HONDA ACCORD
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROBBIE DUNN
Drove the car this morning. When I got home the drivers window rolled up fine. The passenger window would not roll up and neither rear window is working. Checked all the fuses and they are all fine. Is there something that you know of that can cause all the windows except the drivers to stop working. Each window has a different fuse and I've moved them all around so I know its not a problem with fuses because no matter which fuse was in place the drivers window is the only one that will work. Thanks for any help you can provide.
Apr 1, 2010 at 10:05 PM
