1999 GMC Sonoma NO START
1999 GMC SONOMA
P CASALETTA
Electrical problem
1999 GMC Sonoma 6 cyl Four Wheel Drive Automatic 110,O0 miles
NEW BATTERY,ALT,STARTER TESTED GOOD NEW IGN MODULE PLUGS,WIRES CAP ROTOR,COIL PACKAND WILL ONLY START WITH A JUMP CAN ALSO HEAR FUEL PUMP RUN. WHEN RUNNING THE VECHICLE IT RUNS,IDLES PERFECTLY FULL POWER SHUT OFF AND WILL NOT START WITHOUT A JUMP ALL CONECTIONS SEEM INTACT,CLEAN IS THERE A RELAY SWITCH,FUSIBLE LINK THAT MAY HAVE BLOWN OR SHORTED OUT NO CODES BEING SHOWN NO CHECK ENGINE LIGHT EITHER WILL A DIRTY INJECTOR OR WEAK FUEL PUMP CAUSE THIS PROBLEM
Feb 7, 2008 at 4:36 PM
MASTERTECHTIM
  • CAR REPAIR CONTRIBUTOR
  • 4,750 POSTS
does the vehicle even crank over at all or does it crank over slowly? does it crank normal and just not start?
Feb 7, 2008 at 4:38 PM
