1998 GMC Sonoma misfire and stall while driving
1998 GMC SONOMA
205,000 MILES • 4 CYL • 2WD • MANUAL
BELIEVE622
I have a high milage 98 S10 with a manual 5 speed. A few weeks ago I had trouble accelerating from idle. The engine would misfire and the truck would shudder in 1st from a stop. I pulled over and manually moved the throttle under the hood, problem continued. I turned the truck off and let it cool off. It ran fine after that. Figured it might of been a little bad gas. Then today I was driving and I looked down at the gauges to see the voltage meter dancing. Few miles later the truck stalled and all guages dropped to zero and back up again. I pulled over and turned the truck off. Started again and continued home. I checked battery connections, oil, fuel and filters. All seem to be fine. Please help before I get stranded....
Sep 7, 2010 at 3:47 PM
