1994 GMC Sierra rough idle and missing while driving
1994 GMC SIERRA
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIMELAINEDAVID
it does not do this every time I drive it but when I do it stumbles and back fires. 2 months ago it started this I replaced plugs and wires. it worked for a few days then it started it again. when it does this if I let it sit for a few hours or so it MAY start and run fine, then next day out of the blue it starts this again.
Feb 14, 2010 at 5:38 PM
  • CAR REPAIR CONTRIBUTOR
Check and test all the following below:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Feb 15, 2010 at 5:51 AM
