2000 GMC Jimmy Heater core removal
2000 GMC JIMMY
122,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHINGADADDY
This is a diamond addition Jimmy
I have the dash out. I have the front right tire and inner panel off. I have the lower inside bolt out from inside the passenger floorboard. I have the 2 studs in this same area backed out from under the heat shield in the tire well area. I can see they are out from the passenger floorboard area. I have the stud backed out at the firewall heater core hose area in the engine compartment. I have removed the blower motor resistor panel per the manual , and there is NO BOLT TO REMOVE UNDER THERE. Not too happy about cutting that out for nothing. The HVAC module is still tight to the inside firewall area. Where are the hidden fasteners please.
Thanks
Randy
Correction. There IS a bolt and it was hidden under the SILVERY *soft* covering to the left of the inside of the hole. We found it ourselves and the core is out.
Feb 21, 2010 at 2:33 PM
