1994 GMC Jimmy Fuel Pump/ not starting
1994 GMC JIMMY
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
BROKENXANGEL06
I have a 94 jimmy. and i was driving it one day. and it just quit, it would turn over. but the fuel pump would not turn over. I got a fuel pump out of a s10. and it was only about 3 months old. the psi was higher then the pump that was in it. and i also got a new sending unit. With all that in it would still not start. If you put gas right into the intake valves it would start. but only long enough for the gas to burn off. I'm not sure if it is something electrical to do with it. or if it is the fuel. if you have any idea that would be great appreciated. thanks.
Sep 20, 2008 at 7:09 PM
