secondary air injection system
2005 GMC ENVOY
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
STEVEZAZENSKOWSKI
I need to know where the secondary air injection system is? Please.
Dec 29, 2014 at 11:56 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
The secondary air injection system is located under the car on the drivers side at about the transmission. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
Dec 29, 2014 at 12:05 PM
KKBROWN40
Hi, My Envoy has a defective secondary air injection - can I purchase parts and repair myself and if so, how do I do it?
Oct 27, 2018 at 1:56 PM (Merged)
RHALL77
  • 3,361 POSTS
yes you can purchase the parts but make sure you install a new air diverter valve also.
KKBROWN40
What parts do I need and how do I install the new parts and the valve and do you know the approximate cost of parts?
Thanks much.
KKBROWN40
[quote:a6f1749db3="rhall77"]yes you can purchase the parts but make sure you install a new air diverter valve also.[/quote:a6f1749db3]
is the secondary air injection and the air diverter valve easy to install and what is approximate cost of parts?
2CARPRO JACK
  • 11,533 POSTS
check valve is around $140.00 I dont show a listing for the diverter, call your local dealer and they can help you with that part. Yes you can do it yourself, just need afew wrenches and some WD-40 for the valve
CANANBALL03
Ive got a question regarding the secondary air injection solenoid valve. I had my check engine light go on and it came back as a secondary air injection solenoid valve. Any help on where I could pick one up and where is it located on the vehicle? Any feedback would be excellent!!
BMRFIXIT
  • 19,053 POSTS
The valve is located at the right side of engine
I would check with locale dealer for availability
MONICATRAVIS
my check engine light keeps coming on and when hooked to a diagnosis it says secondary air injection malfunction, it has happened a couple of times !! how do i fix this problem my self???? please tell me what to do
BRIAN 1
  • 1,030 POSTS
what was the code?was it a p0410?start with the air pump check valve on the side of the block,they get water in them and get rust and corrosion in them. check that first.
