Air Conditioning problem
1999 GMC C1500 V8 Two Wheel Drive Automatic
I have a 99 gmc suburban 1500 the air in the front does not blow cold but the rear air blows ice cold what could be the problem
Wednesday, August 13th, 2008 AT 10:51 AM
2CARPRO JACK
MECHANIC
Sounds like a blend door problem in the front. Do you feel any temp difference when ypou gop from hot to cold? Will it get cold if you have the front blower on a low fan speed setting? Both would point towards the blend door actuator
