Noise in front end when turning
CWATSON65
  • 2005 SATURN VUE
  • V6
  • 96,000 MILES
I have straining noise in front end when turning left or right noise seems little louder when turning right.
I am single woman and don't have any car knowledge. I do take in for regular oil changes but dad asked about lub job and never requested not sure if done
Thanks for any info you can give
Sunday, November 8th, 2015 AT 7:13 AM
SATURNTECH9
  • 30,869 POSTS
There isnt much to lube in the front end there isnt any grease fittings. It could be that boot thats inside that goes at the base of the steering column. They sometimes get a little rust on them and make noise while turning the wheel left and right. If you lightly grab that boot while turning the steering wheel if its that then you will feel the noise in the boot.
Sunday, November 8th, 2015 AT 8:49 AM
REGINA MATTEAU
  • 2004 SATURN VUE
  • 3.6L
  • AWD
  • 173,000 MILES
I recently bought the car listed above it a v6 awd. I replaced the tires, wheel bearing and hub and front passenger caliper. Now there is a grinding noise coming from that side I believe. When you go above forty miles it is not there but when slowing down to about ten to twenty miles it is there. Just wondering what it can be.
Wednesday, October 30th, 2019 AT 5:23 PM (Merged)
CARADIODOC
  • 33,757 POSTS
The most logical suspect is worn brake pads. One potential clue is if the noise changes when the brakes are applied lightly.
There can also be rust buildup on the brake rotors if the vehicle sat for a while. That will usually wear off within a few miles, but heavy rust can take longer.
Normally we give the front brakes a quick peek when we have the wheels off, and we cannot help but to see the amount of pad wear when replacing a bearing assembly. If the pads were fine, the next suspect is improper installation procedures of the new bearing. There must never be any vehicle weight placed on the new bearing until the axle nut is tightened to specs. Some people set the tire on the ground to keep the axle from spinning so they can tighten that nut. At that point the damage has been done. The new bearing will instantly become noisy and sound like the buzz of an airplane engine.
REGINA MATTEAU
It does not sound like that. It is just a grinding noise when driving it slow when going fast it stops. Will have to check pads and rotors. The drive side rotor is smooth but the passenger side feels like grooves are in it now. Could that be the issue?
CARADIODOC
  • 33,757 POSTS
Grooves do not cause noise. If the linings on the pads are worn down, the metal backing plates and/or the rivets, when used, will cause grooves, and the grinding noise. Very often the pads can be seen through the wheels without having to remove them.
REGINA MATTEAU
Ok so heres where I am as of now. Brake pads and rotors have been replaced. New caliper was put on. When trying to bleed the breaks no fluid comes out breaks do not grip at all when hooking line to caliper. When line off fluid comes out any ideas?
CARADIODOC
  • 33,757 POSTS
I'd have to see that fluid flow to make a diagnosis. If you only get fluid with the hose disconnected, I suspect that fluid is just running out of the line as air goes in.
A failure to get fluid flow is a common problem on GM front-wheel-drive vehicles. There is a valve in the master cylinder that trips when unequal pressures build up in the two parts of the hydraulic system. That stops the loss of fluid when there's a leak, but it will also trip for other reasons. In this case, the valve likely tripped because of the new caliper. The piston in it has to be run out until the pads contact the rotor. That is the self-adjusting feature of all disc brakes.
This vehicle will have a split-diagonal system that puts the left front and right rear wheels on the same circuit. When pumping the brake pedal to run the piston out, no fluid pressure will build up in that part of the system, and that's when the valve will trip. From that point on, no more fluid will flow from the master cylinder to those two wheels. This can be avoided by never pushing the brake pedal past half way to the floor. Professionals never push the pedal over half way on any vehicle more than about a year old to prevent causing damage to the master cylinder. Given the age of your vehicle, this is another problem you might still run into. Crud and corrosion build up in the lower halves of the bores where the pistons don't normally travel. Pushing the pedal over half way runs the rubber lip seals over that crud and can rip them. That results in a slowly-sinking brake pedal, and that often doesn't show up until two or three days later.
The only way I have ever found to reset the valve in the master cylinder is to loosen the cap on the reservoir, open the bleeder screw on only one of the wheels that isn't flowing any fluid, then give it a quick, short burst of compressed air. It just takes a fraction of a second to reset the valve. You want to avoid sending air into the line any further than necessary. That just makes it harder to bleed.
Once the valve is reset, just let the caliper gravity-bleed. It will only take a minute or two. Once the fluid is flowing, close the bleeder, then pump the pedal half way to the floor repeatedly until the piston works its way out of the caliper and pedal pressure builds up. If the piston is already out, just "irritate" the brake pedal by hand a couple of times, then open the bleeder screw once more to burp out the last few little bubbles that got pushed into the caliper.
KCTAXLADY
  • 2004 SATURN VUE
  • 4 CYL
  • MANUAL
Grinding front end noise in wheel area when I turn
Check the wheel bearings and drive axles CV Joints and Boots
SATURNTECH9
  • 30,869 POSTS
Just to add to this one is the noise there while driving?Also the upper strut bearing makes noise on those sometimes I have seen a lot of them that I had to replace.
MHAPKEN
  • 2004 SATURN VUE
  • 168,000 MILES
I've been experiencing an intermittent problem with my 2004 Vue since buying it 2 months ago. The front end periodically shakes & shudders for no reason at all. Since buying the Vue I have changed the from brakes & rotors, thinking this would fix the problem. I also had to have the clutch replaced, as well as the associated hydraulic cylinders. It seemed a little better for a week or so & then started happening again. Last night I noticed the drivers side brakes were smoking when I got home. It's hard to give many more details because there doesn't seem to be a consistent pattern to when it happens.
My Vue is a 2.2L FWD standard. Please ask for any additional information you feel would help identify the problem & suggest the fix. Thank you.
SATURNTECH9
  • 30,869 POSTS
This is going to be a hard one to answer over the internet. Did you make sure the caliper pins etc are freely moving no rust etc?Everything on the front end has been checked tie rods ball joints etc?Also tires wheel bearings?
THIS IS MIKE
  • 686 POSTS
How many miles are on it? Lower ball joints can cause intermittent shakes and shudders. Sometimes wore out suspension parts will react intermittently to small changes in the driving surface. Check the caliper slides to make sure they are moving freely and not locking up causing the front brakes to stay engaged. New brakes will sometimes smoke after being changed, but after a week they really shouldn't smoke at all. Does the shuddering happen while braking, turning or during normal driving?
