Front End noise/roaring
1999 CHRYSLER SEBRING
130,000 MILES
ATH23JAN73
Started out as roaring noise that got louder the faster you drive. It would disappear when you turned to the right. Now it makes a clicking/rattling noise (tinny sounding). I changed the right cv axle but it didn't help it. Have any suggestions?
Nov 13, 2011 at 9:02 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
It sounds like a bad wheel bearing. If it stopped when turning right, chances are it is one of the bearing on the right. Think about it, when you turn right, the vehicle's weight distribution moves to the left removing a lot of pressure from bearing on the right.
That is what I would recommend checking.
Nov 13, 2011 at 9:14 PM
AUGUSTRUSH
97 sebring jxi recently had new tires put on due to right frnt tire belt, replaced ball joints, tie rods, etc. Was pulling into driveway steep incline and then bottem out, didn't seem like any damage upon driving a noise believed to be coming from right front. When I excelerate(gas) no noise soon as don't give it gas and its coasting loud noise like a hollow clunking sound coming from right frnt end, came on immediate, steering doesn't seem effected. any suggestions could tire belt busted again, or control arm??
Nov 26, 2019 at 8:02 PM (Merged)
CADIEMAN
  • 3,544 POSTS
take it back immediately to where you had the work done. Obviously something they have done to the car isn't right. Because you did not have this problem before! You should have just replaced the tire only I feel that they have suckered you in to replacing all these other parts and something hasn't been done right! They should have aligned the front end did they?
AUGUSTRUSH
No alignment done, had tires put on at walmart. would it be the bearings or could the new tire belt broke again?
CADIEMAN
  • 3,544 POSTS
who did the front end work? they should have aligned the front end! You did not have this noise before this work was doneright?it's not the tires are new a bearing would be a constant humming noise. Something was left loose or installed improperly. How long ago was this work done?
