I have to 2000 Windstar - the other when trying to start the Van all I got was a clicking from the solenoid. I have replace both the battery and starter and I am getting the same clicking from the soleonid when the key is turned to the start position. I have verified that the connection at both the stater and battery are clean. I have check and verified voltage at the starter and pin tested the starter relay and both are fine. I have noticed that when the key is turned to start the gaiges on the dash board all peg to the max for each and then return to the starting position.
Feb 12, 2010 at 8:42 PM
