1995 Ford Windstar Repair Question
Topics covered: Spark, Engine, Water pump.
Asked on August 23, 2009
1995 Ford Windstar wont start
Electrical problem
1995 Ford Windstar 6 cyl Two Wheel Drive Automatic 120000 miles
ran hot water pump was place now wont start
Answer
Replied on August 23, 2009
If it wasn't doing that before the water pump was replaced-backtrack your work unable to track it do below to find out what's missing causing it not to start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
