1991 Ford Thunderbird Repair Question
1991 Ford Thunderbird turn signals
1991 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
They don't work. I've had relays go out on other cars before but the difference is that you can operate the light manually, meaning, turn them on and off repeatedly to make them blink. This vehicle I have nothing.
Now is this just a relay or is it deeper, requiring a little digging into the electrical? First were is the relay located at?
Answer
Hello and thanks for the donation!
Your vehicle's turn signal / hazard flasher relay is located behind the dash, right of the steering column. .
So you're saying that the turn signal lamps are not lighting up at all correct? How about the hazard switch, does it operate the signal lamps properly?
My hazards work but my turn signal dont. No illumination or "clicking" when opperating the signals.
Okay, since the hazards do work this eliminates a faulty relay as both the hazards and turn signals use the same relay to function. This leads to either faulty wiring at the multifunction (turn signal) switch or a faulty switch itself.
Oh sh**, that means deeper digging, huh?
Yep, most likely it needs the switch replaced but just to be safe it is always a good idea to check the wiring before purchasing the switch.
Okay. Starting at the switch (which is the lever, correct) and going to the relay or where?
Just visually inspect the wiring at the switch (yes, the lever). If it looks OK, test it with a meter to see if it is getting power when it is supposed to (turned ON ). If it is then wiring is OK and switch is bad. If it's not getting power then there is a open circuit somewhere and I will have to post wiring diagrams for you to follow and inspect on your vehicle.
