1994 Ford Tempo Repair Question
94 Ford Tempo 2.3 no spark
Answer
I have a 1993 ford tempo with a no spark condition similar to yours.The engine cranks but I have no spark.
I tried a shoot gun approach to fix problem,replace coil,entire Distributor with pip and ICM assembly,distributor cap ,wires and so on but still have no spark.The trouble I found out later is the start wire(white with pink stripe) also known as the ignition diagnostic monitor wire.I should have battery voltage coming out from the wire from pin 4 on the eec IV computer to the ICM when the ignition key is in the start position when the S-wire to the starter relay is disconnected for testing but only having .8 volts.
I wanted to know did you ever find out what the problem with your car.I would sure appreciate any info.
Thanks runbebe
