Mechanics
FUEL PUMP RELAY
1993 Ford Tempo
Electrical problem
1993 Ford Tempo 4 cyl Front Wheel Drive Automatic 270000 miles
i have a 93 ford tempo and we cant find where the fuel pump relay anywhere. Not the shut off switch. The fuel pump relay we have looked in trunk drivers side steering column dash under hood under carpet on both driver side and passenger side.I need all possible areas it could be located!
Brittanyblackwell
April 18, 2010.
The fuel pump relay is included in a module under the hood. CCRM
Look at strut tower driver side, rectangle shape, some like 4 x 6 inch black box. You can't miss it.
In the module, there's a relay of the fuel pump, engine radiator fan and ac clutch relay
Hope this helps,
Dan
Dannyr2009
Apr 18, 2010.
AD
