1991 Ford Tempo shuts off
1991 FORD TEMPO
80,879 MILES • 4 CYL • 4WD • AUTOMATIC
TRACEYCAREER
I have a 1991 Ford Tempo GL from time to time my car will cut off for example if im @ a traffic light, or in reverse and sometimes while making turns. What i've been doing is putting the gear in neutral have not had much of a issue when I do that. I've had the spark plugs, altanator, all the oil, fuel filter and thermostat replaced. The check engine light will also come on from time to time will not stay on long. When starting my car it will sputter a little and I'll have to keep the key turned while giving it gas then it'll start. Now thats mostly after driving, what I don't understand is when I get in the car after sitting all night it will start right up.
Aug 4, 2009 at 12:17 PM
