Mechanics
THROTTLE POSITION SENSOR OUT OF RANGE
Ford Taurus
Hi there. I installed a new TPS on my 2001 Ford Taurus SEL w/ 25,000 on it. Now I'm getting a DTC P1120 " throttle position sensor out of range". What does that mean? The repair book says the TPS is not adjustable. ?
Ngrajal
April 30, 2007.
Are you sure you installed it correctly. These are usually spring loaded and have a tang that catches on the throttle shaft. If you didn't put it in the proper position and then turn it slightly to get the mounting holes to line up, you may not be riding on the tang to get the proper readin. Usually the instructions that come with it or the service manual will tell you how to do this.
Or. You could have a defective part.
CraigFL
Apr 30, 2007.
I think I installed it wrong. I basically just placed the TPS in and mounted the screws.
AD
Ngrajal
Apr 30, 2007.
Sometimes you have to use a voltmeter to get the correct setting, the pcm is picking up an incorrect setting, I always scratch the housings to line them up, most have been within range, luckily
TaurusWheel
Apr 30, 2007.
AD
