Transmission problem
2002 Ford Taurus Automatic 150000 miles
I HAVE A 2002 FORD TAURUS. AFTER BREAKING DOWN WHEN RAN HOT AND LOSING ALL FLUIDS A LIGHT SHOWING AN EXCLAMATION POINT WITH A RIDGED CIRCLE AROUND IT STARTED BLINKING. WHEN WE LOOKED IT UP IT SAID IT WAS RELATED TO THE TRANSMISSION. AFTER REPLACING SEVERAL OTHER PARTS THAT OTHERS SUGGESTED MAY BE THE PROBLEM WE DECIDED TO REPLACE THE TRANSMISSION. NOW THE SAME EXACT THINGS ARE HAPPENING AGAIN THAT HAPPENED RIGHT BEFORE GOING SO BAD THE LAST TIME. THINGS HAPPENING, WONT SHIFT INTO GEARS CORRECTLY, RUNS HOT AND LIGHT BLINKS WHEN DRIVING OVER 30MPH, WHILE IN NEUTRAL WITH FOOT ON GAS THE RPM NEVER MOVED. ANY SUGGESTIONS?
Jun 16, 2010 at 10:52 AM
