2CarPros - Car Questions & Answers
1999 Ford Taurus Repair Question
Topics covered: Heater, Heater core, Engine.
Asked on November 2, 2009
1999 Ford Taurus no heat
Heater problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 99000 miles
car has no heat the hoses going to heater core are not hot but bypass is pinching off bypass doesn't seam to help also the ac compresser runs while tring to get heat
Avatar Asked by schrade
Answer
Replied on November 2, 2009
Check coolant level
Is the car reaching operating temp if not remove and replace thermostat
if its reaching operating temp
Check heater core hoses if both are hot ,
if both hoses hot and not enough heat inside suspect blend door actuator
if not one hose hot and the other warm or cold the heater core need to be flushed (very common)
as a 1st step
these are the steps
WARNING: NEVER REMOVE THE PRESSURE RELIEF CAP UNDER ANY CONDITIONS WHILE THE ENGINE IS OPERATING. FAILURE TO FOLLOW THESE INSTRUCTIONS COULD RESULT IN DAMAGE TO THE COOLING SYSTEM OR ENGINE AND/OR PERSONAL INJURY. TO AVOID HAVING SCALDING HOT COOLANT OR STEAM BLOW OUT OF THE COOLING SYSTEM OR DEGAS BOTTLE, USE EXTREME CARE WHEN REMOVING THE PRESSURE RELIEF CAP FROM A HOT COOLING SYSTEM OR DEGAS BOTTLE. WAIT UNTIL THE ENGINE HAS COOLED, THEN WRAP A THICK CLOTH AROUND THE PRESSURE RELIEF CAP AND TURN IT SLOWLY UNTIL PRESSURE BEGINS TO RELEASE. STEP BACK WHILE THE PRESSURE IS RELEASED FROM THE COOLING SYSTEM. WHEN CERTAIN ALL PRESSURE HAS BEEN RELEASED, PRESS DOWN ON THE PRESSURE CAP (STILL WITH A CLOTH), TURN AND REMOVE PRESSURE RELIEF CAP.
Engine cool
lower the coolant level
Locate the two hoses running to the heater core
disconnect them at the engine side leaving hoses connected to heater core throw the firewall
block or pinch the bypass hose
use garden water hose and compressed air if possible
run the water and follow by air throw one side and out the other and vice versa
do that two to three 4 5 times watching what leaving the heater core you are looking for the good flow and clear water to run throw
reconnect hoses
top off coolant system
good luck
let me know
Tiny Answered by BMRFIXIT (expert)
19,736 answers provided
