1997 Ford Taurus No Heat
1997 FORD TAURUS
MEANS
Engine Performance problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic
97 Ford Taurus No Heat,Spudders when in drive sometimes dies (shuts off) Corrosion in Radiator Resovoir. This car has been quated by technicians for a bad Head Gasket. Also for a Bad thermostat and air in the engine. Also Has been said exaust fumes are getting in the engine from manifold causing the corrosion in the radiator resovoir. Car has had pressure check on it and came back with some sort of leak or plug. Just cant narrow it down because of the inconsistency of repair quates. Please help send me in the correct direction and narrow the work needed. The head gasket on this car to be changed by a technician is expensive in the $1500 range due to it being a Dual Head gasket. Please help Means
Nov 22, 2008 at 1:15 AM
