1995 ford taurus 3.0 sohc 158,000. won't start.
1995 FORD TAURUS
ROBERTANDTRACI
This car died while going down the freeway. Would not start after that. We checked the fuel pressure and it was below specs. Changed the fuel pump. Also found bad coil wire and a weak spark. Control module also tested bad. So far, we have replaced the fuel pump, fuel filter, coil, coil wire, control module, checked timing, checked for injector pulse, and checked fuses and relays. We also hooked the car up to a scanner and there were not any trouble codes. We are lost.
Apr 15, 2007 at 10:41 PM
  • CAR REPAIR CONTRIBUTOR
[quote:b36fc3a927="robertandtraci"]This car died while going down the freeway. Would not start after that. We checked the fuel pressure and it was below specs. Changed the fuel pump. Also found bad coil wire and a weak spark. Control module also tested bad. So far, we have replaced the fuel pump, fuel filter, coil, coil wire, control module, checked timing, checked for injector pulse, and checked fuses and relays. We also hooked the car up to a scanner and there were not any trouble codes. We are lost.[/quote:b36fc3a927]
Try the crankshaft position sensor or Magnetic pick up in the distributor if it has one.
Apr 16, 2007 at 6:34 AM
