1992 Ford Tauruas L 3.8 liter engine
1992 FORD TAURUS
TIM0324
I was turning into a parking lot and hit a dip and lightly hit front end of the car; then the car just quit running. It will not start again. There is no fire going to the spark plugs the engine turns over as if trying to start. I have replaced the coil and rotor button; the battery is charged. It is not out of gas. I've checked all the fuses and have no blown fuses. What could the problem be?
Sep 3, 2007 at 9:27 AM
  • CAR REPAIR CONTRIBUTOR
[quote:014eadd8e4="tim0324"]I was turning into a parking lot and hit a dip and lightly hit front end of the car; then the car just quit running. It will not start again. There is no fire going to the spark plugs the engine turns over as if trying to start. I have replaced the coil and rotor button; the battery is charged. It is not out of gas. I've checked all the fuses and have no blown fuses. What could the problem be?[/quote:014eadd8e4]
Do you have power going to the coil positive terminal-if so remove distributor cap crank it over-is the rotor spinning?
Sep 3, 2007 at 3:46 PM
