where is the cabin air filter located?
2007 FORD RANGER
LORAINE
Air not coming into the cab of truck
Jun 25, 2012 at 6:37 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
This truck does not have a cabin air filter. Here is a web capture from ALLDATA (below)
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Jan 20, 2018 at 7:24 PM
HUMBIRDS
I am trying to find the location of the cabin filter for a 2005 Ford Ranger xlt. Our truck did not come with a manual and we would like to change the filter but can not locate it. Thanks for your help.
Jan 20, 2018 at 7:25 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
I went to 4 on-line sites, at 3, I just looked for a filter for your application....They showed a bunch, but none for yours.
Maybe you do not have one?
Maybe you can check for one too, I may be throwing mis-information
The Medic
NATE A. SPRAGUE
I was looking for the same thing for my 07 Ranger. All the info I have found is that the Ranger doesn't have an AC filter. There is plastic mesh to prevent debris from getting into the hvac but no filter
  • 54,354 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
GRAMAW7
how to change air cabin filter on a 1999 Ford Ranger
You don't have one
RUSFULL
Interior problem 6 cyl Four Wheel Drive Automatic 89,000 miles
interior has a musty odor .i would like to change the cabin filter. could you tell me its location and how to acsess it .this is my first time to your sight .
  • 54,354 POSTS
This truck does not have a cabin air filter. Here is what the book says "This model is not equipped with a cabin air filter"
Cheers, Ken
MARY WARREN
2003 Ford Ranger
location of cabin air filter
Air Distribution
NOTE:The air distribution system of this vehicle cannot be equipped with a cabin air filter.
There are two sources of air available to the air distribution system:
*outside air
*recirculated air
Recirculated air is only used during MAX A/C (if equipped) and OFF modes.
Air distribution within the vehicle is determined by the function selector switch position. Airflow control doors are used to direct airflow within the air plenum chamber. Vacuum control motors (18A318) are used to position these airflow control doors. Refer to CLIMATE CONTROL SYSTEM - GENERAL INFORMATION for a description and operation of each of the system functions.
The air distribution system is designed to provide airflow from the defrost nozzle when no vacuum is applied to any of the vacuum control motors. This is done to prevent a situation where defrost cannot be obtained due to a system vacuum leak.
Air enters the passenger compartment from the:
*instrument panel A/C register (19893).
*heater outlet floor duct (18C433).
*windshield defroster hose nozzle (18490).
*side window demisters.
Passenger compartment air is exhausted from the vehicle through open windows or cab air vents.
TDTRUCKGUY
does a 2003 ford ranger have a cabin filter?
Jun 28, 2020 at 12:40 PM (Merged)
  • 54,354 POSTS
From the manual:
Note: The air distribution system of this vehicle CANNOT be equipped with a cabin air filter.
PALKA
Where is the cabin filter in a 2003 Ford Ranger? How do I change it?
  • 110,190 POSTS
If it has one the cabin filter is behind glove box.
SWITTY123
  • 5 POSTS
Does a 1994 Ford Ranger STX Ext Cab 4x4 have a cabin air filter? I do already know it has an engine filter but I don't know about the cabin filter.
thanks
switty123
Mar 20, 2021 at 6:52 PM (Merged)
This model is not equipped with a cabin air filter.
SWITTY123
  • 5 POSTS
ok thanks
