window replacement
FORD RANGER
NBLACK20
  • 10 POSTS
How do you change the passenger side window on a 1996 Ranger, crank type window
Oct 9, 2007 at 4:16 PM
FAIRRACING31
  • CAR REPAIR CONTRIBUTOR
  • 150 POSTS
1. Remove the door trim panel and watershield
2. Remove door speakers if equipped.
3. Raise the window all the way.
4. Detach the rear glass run retainer from the door and take it out.
5. Lower the window enough to provide access to the glass braket and retention rivits. Tap the center pin out of each rivet with a punch, then drill out the rivets with a 1/4-inch drill.
6. Lift the glass out through the top of the door.
7. Installation is the reverse of the removal steps with the following: A) Lubricate the regulator rollers, shaft and tracks with multi-purpose grease.
B) Raise and lower the window to check its operation before installing the speakers, watershield and door trim panel.
Adjustment: Lower the glass two-to-three inches from the full-up position. Loosen the three guide assembly nut and washer assemblies. Push the glass toward the rear until it bottoms out within the door frame. Move the window guide post toward the rear within the retention slot in the door inner panel. Tighten the three guide assembly nuts securley. Raise and lower the window several times and check for proper fit.
See the attachment below
Oct 20, 2007 at 2:35 PM
BRYONS1
How do I remove a window crank so that I can get the inner door panel off?
Mar 11, 2019 at 5:16 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
There is a special tool to remove the clip.....or if you hold a rag at both ends and feed the center in behind the handle, now use the rag like you are cleaning behind the handle and rotate it around , it should grab the end of the clip and pop it out
Check out this video, shows you how
https://youtu.be/6VRv9TNrxVY
