How do I change fuel line coming from tank to filter
MIKEDIP
  • 1999 FORD RANGER
  • 80,000 MILES
Have pin hole leak in line
Monday, September 5th, 2011 AT 12:59 PM
  • 108,328 POSTS
The only thing you can do is remove the tank, purchase a spool of steel fuel line and replace it. It isn't a fun job, but that is what needs done. Chances are you won't be able to purchase the factory part anymore. If you can, get it! It will make your life much easier.
Tuesday, September 6th, 2011 AT 3:34 AM
2CP-ARCHIVES
  • 4,540 POSTS
  • 1999 FORD RANGER
  • 156,000 MILES
Looking for the fuel line in the engine. Would like to have a diagram of where it is in the engine if possible.
Tuesday, December 17th, 2019 AT 3:50 PM (Merged)
  • 108,328 POSTS
I don't have a diagram for the fuel line. However, it just attaches to the fuel rail. What specifically do you need to know?
JOE1953
  • 619 POSTS
  • 1999 FORD RANGER
  • 2.5L
  • 4 CYL
  • RWD
  • MANUAL
  • 186,000 MILES
Do I need a special tool to disconnect the fuel lines?
WRENCHTECH
  • 20,758 POSTS
Yes, you do.
https://www.2carpros.com/images/external/ASM8027.jpg
JOE1953
  • 619 POSTS
Can you send me pictures showing how to disconnect the fuel lines from the tank?
WRENCHTECH
  • 20,758 POSTS
There are no such pictures. You slide that tool up the line and it releases the lock clip inside.
PURPLERENEE
  • 1995 FORD RANGER
  • 4 CYL
  • FWD
  • 20,000 MILES
How much should it cost to have the fuel line replaced, it didn't pass inspection?
  • 108,328 POSTS
If you are replacing from the tank up to the fuel rail, around 30.00 in material (unless you replace the fuel filter which I recommend). The labor is where the problem is. The fuel tank needs removed to access all of the steel line. I would estimate around 4 hours in labor x hourly rate.
DAVE_SIEBERT
  • 1995 FORD RANGER
  • 6 CYL
  • 168,000 MILES
I bought a 95 ranger with a smashed windsheild and a bent down roof. I own another ranger with a good cab I have been told changing out cabs is easy (comparatively) and its only 6 bolts one wiring harness radiator hoses and ac lines. Other people have told me its more involved with steering components and brake lines fuel lines and more.
  • 108,328 POSTS
The "other people" are correct. It is more involved. You will need to remove everything from the firewall.
