1995 Ford Ranger clutch pedal goes to floor but does not di
1995 FORD RANGER
212,000 MILES • 6 CYL • 2WD • MANUAL
B.PAT88
I was having trouble shifting from gear to gear. I checked the clutch fluid resevoir and needed to add. After adding fluid, my clutch will randomly go all the way ot the floor but not dissengage like it should. I believe I have caused an air pocket in there when I added the fluid because it was so low. The clutch is fairly new, and the transmission is also OK. I need to know how to bleed the air pocket out of the clutch line.
Feb 19, 2010 at 1:01 PM
