1994 Ford Ranger 1994 Ranger 4.0L No Start/No Spark
1994 FORD RANGER
14,300 MILES • 6 CYL • 4WD • MANUAL
CHRIS LOMBARDO
I have a 1994 Ford Ranger 4.0L that will not start. No prior symptoms have been present. I have verified fuel pressure @ 48psi and no spark is present. I also performed an output test at the CKP sensor and found it to be 1.3v ac during cranking. I performed an ohms continuity test on the CKP circuit and found no peculiarairties present. I have power present at the coil pack when in the run position of ignition switch. I then went and replaced the ICM and still no spark! One thin I do note is that the MIL light does not illuminate at the instruement cluster and I am unable perform either KOEO or KOER tests. Any solutions and or suggestions would be greatly appreciated.
Jul 5, 2008 at 10:00 PM
