just replaced slave cylinder. Went to start engine and all it does is turn over. The fuel pump relay clicks, but no noise from the fuel pump. There is no fuel pressure at the throttle body. Is there a bad ground somewhere, or will I have to replace the fuel pump without being sure that it's the problem? The truck ran fine before the slave cylinder went south. The battery was disconnected per instructions before any work was done. Could the wires in the wiring harness been damaged. We had a heckuva battle getting the transmission out. Any suggestions would be greatly appreciated. Thanks
Jul 29, 2010 at 9:51 PM
