Engine Mechanical problem
1992 Ford Ranger 4 cyl Two Wheel Drive Manual
The truck won't start. Will turn over and will pop thourght the intake. When it did start It was like you had to wind up the motor. The fuel rail does have gas. The spark plugs are firing. Compresion is above 100psi on all cylinders. I'm leaning to the crankshaft sensor but I don't know how to test to see if it is bad.
Thanks in advance
Thanks in advance
Mar 10, 2010 at 10:01 PM
