I need the firing order for a six cylinder 2.3 liter engine for the truck listed above.
Oct 17, 2020 at 6:45 AM
CAR REPAIR CONTRIBUTOR
Please see the attachment for the firing order information for the 2.3L. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Let us know if you need more info. Thanks
Images (Click to enlarge)
Nov 14, 2020 at 4:59 PM
SPITEFIRE
MEMBER
1 POST
I need the firing order for my six cylinder Ranger with a distributor.
Jun 9, 2021 at 1:59 PM
(Merged)
Here is a diagram of the firing order for your truck.
Let us know if you need anything else.
Image (Click to enlarge)
(Merged)
NICK LUCERO
MEMBER
Need diagram for firing order.
(Merged)
Please see attached. Let us know if you need more info. Thanks
Jun 9, 2021 at 2:00 PM
(Merged)
NICK LUCERO
MEMBER
It's got 8 plugs.
(Merged)
Correct. But this is a 2.3L correct? If it is then you have what is called a waste spark plug. I included a picture of both sides of the engine. You have a coil pack on both sides that has the same firing order of 1-3-4-2.
Take a look at all this info and let me know if you have questions. Thanks
(Merged)
TKSTOWERS
MEMBER
how do I line up the marks both dots up or facing each other or what? which way does the firing order on the dist cap go counter clock or clock
(Merged)
See below
(Merged)
TKSTOWERS
MEMBER
thanks that helps would you have an illustration for the timing marks? this would be helpful
(Merged)
Are you talking about the sprockets alignment? If so see below
i know the firing order on block cant find firing order on distributor
(Merged)
BMRFIXIT
Good luck.
(Merged)
WESDURYEE
MEMBER
1 POST
I put new distributor and wires in and and lost track of which were went where. Want a picture of firing order
(Merged)
JDL
I have seen pictures that were not accurate.
(Merged)
PACHYAUTO63
MEMBER
Can you show me the firing order?
(Merged)
JDL
This is for 2.9L engine. Hope it helps.
(Merged)
COLETURNER08
MEMBER
I have a 1986 Ford Ranger with a 2.3l. The block is a 1989 and the rest is a 1986. I got spark and gas. The timing is set to specks with cam and crank but it don't want to start. Could it be the computer or the cylinders.
Could the cylinders be reversed?
(Merged)
MERLIN2021
order is 1-3-4-2 for BOTH coil packs
(Merged)
MERLIN2021
cams are different on 86 and 89, what cam is in it?
(Merged)
BUSHWACKER85
MEMBER
1 POST
can you tell me the firing order for plug wires.
Jun 9, 2021 at 2:01 PM
(Merged)
MERLIN2021
(Merged)
LAZYGAZER
MEMBER
What is the firing order foe a 89 ford ranger 2.9 v6
(Merged)
320HPPONY?
MEMBER
I have a small collection of Chiltons. I do not have one for your truck but Ford has this thing about being consistent. Do not quote me on these but I am confident this is correct. The Firing order is as follows: 1-4-2-5-3-6.
(Merged)
