1988 Ford Ranger No start
1988 FORD RANGER
120,000 MILES • 6 CYL • 4WD • MANUAL
BNOWLIN
Engine turns over but will note start. Cranks when stater fluid is sprayed cuts off after fluid burns off.
thinking fuel pump or pumps it has two. Is there a relay in the system if so where is it located. I recently charged the battery and when I reconetted the cables I heard a cliking nose then it stop cranking. It cranked fine before the baterry charge.
Sep 24, 2008 at 11:33 AM
