Should fuel/gas flow through and out of the vacuum end of the fuel regulator?
1989 FORD RANGER
SPAIR TIRE
  • 6 POSTS
Should fuel/gas flow through and out of the vacuum end of the fuel regulator? If it flows through mine do I need to replace?
Apr 29, 2009 at 1:39 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
No the fuel pressure regulator is bad and needs to be replaced here are the introductions in the images below to show you how. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Apr 29, 2009 at 7:02 PM
SPAIR TIRE
  • 6 POSTS
[quote:848d179a03="bluelightnin6"]Most modern fuel injected cars run a fuel pump in the tank and run much more fuel than is needed to the fuel rail. A regulator keeps a certain amount of fuel pressure in the rail and then sends the rest back to the tank. Your regulator is working normally if it is doing this.[/quote:848d179a03] Fuel should not flow threw the regulator and out the vaccume. If it does the regulator is ruptured, and must be replaced. That was the answer I obtained by refourmating thr question. Thank You much for your response "spair tire"
May 1, 2009 at 12:21 PM
SPAIR TIRE
  • 6 POSTS
Engine Mechanical problem
1989 Ford Ranger 6 cyl Four Wheel Drive Manual
Should gas flow thru the regulator, and out the vacume line?
Aug 21, 2020 at 12:52 PM (Merged)
Replace the regulator its ruptured-
ALBERT FOSTER
How do I replace a Fuel Pressure Regulator on my 1987 Ford Ranger. I got two screws out but I cant get the one at the tip of it.
Aug 21, 2020 at 12:53 PM (Merged)
HMAC300
  • 48,601 POSTS
you have to get all the screws out first. then it just comes out.
DJHAHN
what is the step by step procedure for replacing the fuel pressure regulator
RANGERDANGER17
  • 224 POSTS
1. Remove vacuum line at pressure regulator, then the regulator housing attaching screws.
2. Remove pressure regulator assembly, gasket and O-ring.
3. Reverse procedure to install, noting the following:
a. Lubricate fuel pressure regulator O-ring with suitable oil before installation.
b. Torque regulator housing attaching screws to 27 - 40 inch lbs. on 4-140, V6-183, 6-300 and V8-302 engines, or 71 - 102 inch lbs. on V6-177 engine.
See diagram below for more info
