Car will not start
AUSTIN78989
  • 1997 FORD PROBE
  • 2.5L
  • V6
  • FWD
  • MANUAL
  • 170,000 MILES
A family member of mine took car to a cheap mechanic shop to get the clutch replaced.
Apparently the clutch was replaced successfully, but the car will not start.
The lights work, dash lights come on etc, and the engine tries cranking however the vehicle does not start.
I am thinking it may be the PNP switch is unplugged or not plugged correctly because in the clutch replacement process it is one of the only sensors that gets tampered with that would prevent the car from starting after replacing the clutch.
I may also look into the inertia switch, maybe the wannabe mechanics dropped something?
Apparently the vehicle started just fine before going into the shop.
I would like to know if there is anything that would prevent the car from starting that I may be missing? I am getting the car from this family member for free if I can get it to start. However, I am in another state and I need a list of things to check when I get there.
Sunday, April 10th, 2016 AT 8:32 AM
HMAC300
  • 48,601 POSTS
Try resetting security system it was probably engaged. If no manual look online on how to do it for your car.
Sunday, April 10th, 2016 AT 11:12 AM
AUSTIN78989
  • 17 POSTS
I have read conflicting information that ford may have removed the anti theft feature from the arc correct me if I am wrong. As for spark and fuel my uncle is a retired mechanic and is going to take a look at it and tell me if it tries starting with some fuel in the carburetor. He says the PNP switch would prevent cranking of the engine at all if it where to be malfunctioning. "Not sure if this is with all vehicles so that may still be an option" I cant take it back to the shop the work was done as that shop no longer exists. I will keep this post updated as I get more information. I will also look into the PNP connection if nothing else works. Any extra thoughts would be much appreciated. The car went in running, came out cranking but not starting.
Sunday, April 10th, 2016 AT 12:55 PM
HMAC300
  • 48,601 POSTS
You can always jump the switch with a jumper wire as long as it is in neutral and the parking brake is on. That would tell you if that was the problem. But if the car's starter turns the engine over it is not the pnp switch.
Sunday, April 10th, 2016 AT 1:26 PM
AUSTIN78989
  • 17 POSTS
The car came out of the shop cranking but not starting* anyway yeah I think the PNP switch is ruled out. Hopefully the fuel pump/filter is not toast I cant see how the pump would just die after the clutch was replaced, but it will be a lot of fun dropping that gas tank if it the fuel pump died. Is it possible that the clutch isn't aligned properly keeping the engine from starting?
Sunday, April 10th, 2016 AT 3:35 PM
HMAC300
  • 48,601 POSTS
No because it turns over. Check fuses under hood and try a security reset like I said in first reply.
Sunday, April 10th, 2016 AT 4:34 PM
AUSTIN78989
  • 17 POSTS
Okay sorry for the long delay, the car has been through a lot of checking. So the engine cranked, but got no fuel pressure or spark. The car may have been sabotaged while in some of the cheap shops it was sent to here is why I think that. We checked the engine fuse box and found a missing fuel pump relay. So we had to go out and buy a new one, we then found that the fuel pump would kick on and supply the engine with 25-30 pounds of pressure, this is below factory and the fuel pump probably needs to be replaced, but it should be enough to atleast get the car to start atleast for a moment. At this point the car still wasn't starting, (no spark) so we decided to replace the Distributor because in the 1997 version of the car the Crank position sensor is in the distributor, so we would be killing two birds with one stone. Success. Kind of, now the engine sparks, cranks, and fuel pressure is good. But the injectors are not firing. We found a plug that had multiple wires going to it, but the bridge plug thing that grounded all the connections was missing (another sign of sabotage) I'm not sure what the plug is called, but we found that by bridging the wires together using some wire connectors everything seems to come to life. The car wasn't getting spark or fuel before fixing those wires. The sparkplug wires where randomized in the original disty (yet another sign of sabotage) and the fuel cut off switch was triggered, nothing major has been noticed other than those issues. The car has little signs of rust, and will start puffing if you put gas directly into the intake. So the only issue we have now, is the injectors are not firing to give the engine fuel to start. What would prevent the injectors from firing? We have tried two computers as well.
Monday, July 18th, 2016 AT 10:05 AM
HMAC300
  • 48,601 POSTS
Scan for codes first you need to see if there is a code set causing the problem. With everything that has been changed there probably is a lot of times it's an iginition problem not allowing injector to fire. Check fuses underhood as well.
Monday, July 18th, 2016 AT 12:18 PM
HMAC300
  • 48,601 POSTS
More things to look at
AUSTIN78989
  • 17 POSTS
So I just got off the phone with my uncle who is working on the car currently, and after some messing around the injectors are finally firing, however the pump is no longer sending any pressure to the engine, when he gets time he is gonna bypass the fuel pump and force gas directly into the line to see if the engine starts sputtering or starts briefly. If so, we are gonna drop the tank swap out the fuel pump/strainer, and possibly the float as well (the fuel gauge is stuck on E all the time). Hopefully the car will fire right up, he made sure that the timing belt didn't skip any teeth as well, so hopefully the car will start soon.I'm getting excited, almost out of the woods :D
Monday, July 18th, 2016 AT 1:56 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
Nice to hear, please let us know what happens. Happy Holidays!
Best, Ken
Monday, December 19th, 2016 AT 11:38 AM
AUSTIN78989
  • 17 POSTS
I forgot about this post oops.
I'm sorry It took so long to reply, but I finally have hands on the car, and I got it started. The timing belt was bad (Timing belt was way off), distributor was also bad, fuel tank was full of sludge, and the fuel pump was rusted out. The strainer for the Fuel pump was disintegrated, the fuel filter was rattly and broken, the fuel pump relay was missing.
Vacuum leaks all over the place (I replaced all of the vacuum lines, and Intake, throttle body gaskets)
Once all of that was taken care of I got the car to fire up.
- Other issues
thermostat bad - fixed
battery bad - fixed
ac leak -fixed
2 bad o2 sensors - fixed
Bad knock sensor - fixed
all 4 brake rotors rusted badly - fixed
Spark plug wires bad - fixed
MAP sensor causing fuel trims to spike and fall rapidly - asking about in another post.
Etc etc.
So my uncle did a bit of tinkering around with the car, but after I got ahold of it I did all of the work above myself.
I actually have a new issue regarding open loop, but that will be in posted in a new question to keep things organized.
Thanks for the help of everybody who chimed in. It turns out pretty much everything was preventing the car from starting, Air, spark, and fuel where missing.
Friday, October 20th, 2017 AT 8:03 PM
KEN L
  • 42,904 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
Saturday, October 21st, 2017 AT 11:38 AM
1997FORDPROBE
  • 1997 FORD PROBE
Engine Mechanical problem 4 cyl Two Wheel Drive Automatic
I have a 1997 Ford Probe GT 4 cyl will not start. I have heard it might be the distributor or the ICM but I can't seem to locate the ICM anywhere.
Saturday, October 21st, 2017 AT 11:39 AM (Merged)
Do below
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
MBARIZIA
  • 27 POSTS
  • 1997 FORD PROBE
  • 130,000 MILES
Hi, I have ford probe 2.0 1997, overheated causing blown head gasket, resurfaced the head and changed the headgasket and now it doesn't start,
checked the timing belt and it's set correctly, spark plugs are new, checked the spark on the wires comming from the coil and all have a spark, checked all wiers and hoses and everything is in its place, after a contious try crancking only the first and second cyl got warm, the fourth and third cyl still cold so now burning on those cylinders. What could be the problem?
MBARIZIA
  • 27 POSTS
Is there any adjustment should be done to the ignition coil? I saw there's a brace there and wonder if it has a role on timing adjustment?
MERLIN2021
  • 17,250 POSTS
Did you recheck the compression?
MBARIZIA
  • 27 POSTS
No I didn't, the 10 bolts have been torqued following the sequence provided on hayness manual.
MBARIZIA
  • 27 POSTS
Would like to add an input here, it has a steady crank and no "pop" there or backfiring, but when I touch the exhaust tube for Cyl 2 is warm! The first is less warm than 2. Cyl 3 and 4 are totlly cold.
MERLIN2021
  • 17,250 POSTS
Three needed items for success are fuel, spark, and compression. Cheerful all three and post findings.
