1994 Ford Probe Repair Question
Topics covered: Noise, Click, Timing belt.
Asked on September 29, 2010
1994 Ford Probe Clicking noise after replacing timing belt
Engine Mechanical problem
1994 Ford Probe 4 cyl Front Wheel Drive Manual 180000 miles
I have a 1994 Ford Probe SE 2.0. I recently replaced the timing belt, idler pulley, tension pulley and water pump. It now seems to have a clicking noise during a cold start up. As it warms up the clicking noise gets less noticeable. It sounds almost like a lifter but, it just seems ironic that it would make that noise after changing the timing belt when it was not making it before. I checked out the new pulleys and they appear to be good. What could it be?
Answer
Replied on September 29, 2010
Have you re checked that the belt tension is correct?
Mark (mhpautos)
