1993 Ford Probe Clutch slippage
1993 FORD PROBE
JSWASKIEWICZ
Transmission problem
1993 Ford Probe 4 cyl Two Wheel Drive Manual
When I am in 5th gear cruising down the freeway, i note that over time the rpms slowly go up as the speed stays the same and the road is level. Also if I step on it hard to accelerate the engine sometimes revs high with no large amount of speed gain, this will occur in almost all gears.
Dec 5, 2009 at 12:49 PM
