Oil Leak
DAVEBAZ
  • 2006 FORD FUSION
  • 2.3L
  • 4 CYL
  • MANUAL
  • 225,000 MILES
Hey, I just found my car with a huge puddle of oil under. I do know that my car burns a lot of oil because my piston rings are done, but it didn't leak. When I jacked up my car and looked, I saw the oil coming from a little hole under the engine (see pictures). I'm not ready to put any more big money into this car since the piston rings are done and it already burns oil.
Are you able to tell me what is causing this leak? It's not coming from the pan or spark plugs, it's directly from that hole.
Monday, July 6th, 2015 AT 3:55 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
This leak is showing you the rear engine main seal has gone out and needs to be replaced, here is a guide hat will show you what you are in for when doing this job.
https://www.2carpros.com/articles/crankshaft-main-seal-replacement-rear
Your car will be different but the procedure is the same.
Cheers, Ken
Tuesday, May 16th, 2017 AT 7:10 PM
LOVELY10
  • 2007 FORD FUSION
  • 6 CYL
  • 4WD
  • 57,899 MILES
Engine Performance problem
2007 Ford Fusion 6 cyl Four Wheel Drive Automatic 57899 miles
Got an oil change n a leak was found. How much will it cost to fix.
Tuesday, May 16th, 2017 AT 7:10 PM (Merged)
KEN L
  • 42,883 POSTS
This job should cost between $900.00 and $1100.00 (US)
Please use 2CarPros anytime, we are here to help and tell a friend.
Cheers, Ken
Tuesday, May 16th, 2017 AT 7:11 PM
