Fuel filter
SLIMCHRIS01
  • 2009 FORD FOCUS
  • 4 CYL
  • FWD
  • 30,000 MILES
My owner guide of my 2009 Ford Focus SE states I have a lifetime fuel filter and does not need to be change but I'm uncertain on what to do since it's due for a 30,000 maintenance and if I need to replace it where do locate the fuel filter?
Monday, May 16th, 2011 AT 3:01 AM
JDL
  • 16,098 POSTS
It's part of the fuel pump module in the gas tank.
This video will show you how to change it out.
https://youtu.be/D1AyqeftAmA
Monday, May 16th, 2011 AT 2:53 PM
DELLISON
  • 2001 FORD FOCUS
Engine Performance problem
2001 Ford Focus 4 cyl Front Wheel Drive Automatic
The low fuel light came on late last night after a long trip. After a fill-up and driving a few miles, the car shutdown at a stop sign. The relays and fuses checked good. The fuel pump was tripped, but checked good after reset. I bought a fuel filter, but I can't locate the old one. All help wil be much appreciated. Thanks in advance.
Friday, March 1st, 2019 AT 7:39 PM (Merged)
RENAUDTN
  • 636 POSTS
Crawl under your car on the passenger side.
Your filter should be right beside the fuel tank, in line with your fuel line (obviously :) )
RAYWILLIAMS91
  • 2000 FORD FOCUS
  • 4 CYL
  • FWD
  • 135,000 MILES
I believe I have a clogged fuel filter I need to know where it is located so I can replace it
Friday, March 1st, 2019 AT 7:40 PM (Merged)
RENAUDTN
  • 636 POSTS
It is right by your fuel tank with one line going in and another going out. It's not a hard job to replace but there's very little room to do it. Make sure to release the fuel pressure before you start.
TOURIESMOM
  • 2000 FORD FOCUS
2000 Ford Focus
instructions on how to change fuel filter on 2000 ford focus 16valve dual overhead cam
thanks
BUDDYCRAIGG
  • 2,262 POSTS
Turn ignition off
Disconnect the battery ground cable
Relieve the fuel system pressure.
Raise and support vehicle.
Remove left front wheel.
Remove left wheel well splash shield including screws and pin type fasteners.
Disconnect the fuel line R shaped clip fittings.
Remove the bolt at the fuel filter bracket and remove fuel filter.
FDIMARINO
  • 2006 FORD FOCUS
Engine Mechanical problem
2006 Ford Focus Two Wheel Drive Manual
how to change a fuel filter
NOTE: 2.0L engine shown, 2.3L engine similar.
https://www.2carpros.com/forum/automotive_pictures/12900_ff_34.jpg
With the vehicle in NEUTRAL, position it on a hoist.
Release the fuel system pressure.
Press the quick connect fitting tabs and remove the fuel filter inlet and outlet tubes.
NOTE: Observe the direction of the flow arrow.
Loosen the bracket retaining bolt and remove the fuel filter and bracket assembly.
To install, tighten to 11 Nm (8 lb-ft) .
To install, reverse the removal procedure.
