1988 Ford Festiva
1988 FORD FESTIVA
WILLY
My Festiva has started running bad, stallling and at times will not even idle. Last summer a mechanic found a burnt fusible link and replaced it. Within a couple days it blew again. I thought it was for the AC, which doesn't work so I wasn't too worried. Now I have been told it is for the 'ptc carburetor heater'. Is this a replaceable part, or must the carb be replaced? What is a carburetor heater anyhow? It has been cold and wet weather if that makes any difference.
Thanks
Dec 28, 2006 at 12:32 AM
AUTOPRO
  • CAR REPAIR CONTRIBUTOR
  • 45 POSTS
Carb heater is a device that heats up air / fuel in the morning for easier to start . That may be has a electricle short or draw too much curent , caused burn out fusiblink . What I said here, is based on theory only. I wish i can help u fix it .
Dec 28, 2006 at 12:56 AM
