bad turbo ? do I need to replace it?
2007 FORD F-350
190,000 MILES
MISSY14
What symptoms are there in a 6L turbo diesel ford when the turbo is gone?
Jan 27, 2013 at 3:59 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
normally it doesn't run right, no power, excessive smoke and oil consumption
Jan 27, 2013 at 4:28 PM
MISSY14
Could it be a hose that popped off or with a hole in it? There is a very loud whisple
Jan 27, 2013 at 4:42 PM
HMAC300
  • 48,601 POSTS
if a hose popped off it may be a vacuum line if it keeps popping off have it checked because it may be pressureizing the crank case. to much.put the hose back on
Jan 27, 2013 at 4:50 PM
MICHAEL W ADAMS
This morning my truck was fine and running perfect. I shut it off for about an hour and when I left again I felt a miss and it started smoking when accelerating. When I reach speed its minimal smoke. But at slowest speeds and take off is when it happens. but this morning it ran perfect. I changed the oil put injected cleaner in it and changed the fuel filter. It's a powered role 6.0 diesel how do i replace the turbo?
Dec 31, 2020 at 9:51 AM (Merged)
I attached the procedure for replacing the turbo for you. Trust me, it is tight to get to everything. the first thing I would check is the turbo. Remove the inlet hose and look for signs of oil. You may have a failing turbo.
REMOVAL
All vehicles
1. Remove the turbocharger intake tube.
2. Disconnect the charge air cooler inlet pipe.
3. Remove the push pins.
4. Disconnect the two wiring harness push pins and position aside.
5. Disconnect the turbocharger variable vane hydraulic control valve electrical connector.
6. Remove the bolts for the oil supply tube.
Remove and discard the gasket.
7. Remove the bolt and the wire retainer.
8. Remove the marmon clamp from the turbocharger outlet.
9. Remove the marmon clamp from the turbocharger inlet.
Early build
10. Using the special tool, remove the oil feed tube.
11. NOTE: Turbocharger shown removed for clarity.
Remove the rear turbocharger mounting bolt.
Late build
12. Remove the bolt and turbocharger oil supply tube.
Remove and discard the O-ring.
13. Remove the rear turbocharger mounting bolt.
All vehicles
14. NOTE: Left side shown, right side similar.
Remove the front mounting bolts.
15. Position the turbocharger and remove the turbocharger drain tube.
Remove and discard the drain tube O-rings.
POWERSTROKE MAN
I have an 2002 f350 7.3L powerstroke, just out of the blue the turbo started getting hot even without a load behind the truck. I had a Superchip programmer but returned it to stock and the turbo still gets up to almost 1200 degrees if I pull out to pass a line of cars. Installed new air filter, fuel filter and had an oil change, right after i started noticing the problem. HELP!!!!
MADMIKE1735
  • 951 POSTS
do you have a boost gauge??? your turbo heats up with exaust gas..... if you have a wastegate stuck closed, your exaust is staying in the turbo longer, and creating this heat... if thats the case, your boost should be higher than normal....
BK13JR
Engine Performance problem
2002 Ford F-350 V8 Two Wheel Drive Automatic
While I was driving down the road I heard a pop then a whistling noise like a tire losing air but all tires checked out to be fine I can still hear the turbo whistling so it is still working but I do have loss of power. I dont have the power like I used to while pulling my 3 car trailer. I checked the 2 boots or pipes coming from the intercooler to the turbo and they are fine and I cant find a diagram on the computer anywhere for all the turbo hoses to check to see if I am missing any. Does anyone have any suggestions on what to do or what my problem could be, I was told I blew a turbo hose or boot.
Dec 31, 2020 at 9:52 AM (Merged)
TECH1FORD
  • 102 POSTS
check the intercooler itself they did blow out check where the plastic goes to the side and you will see the rubber hanging out of the side, or eles check the 2 orange boots under the turbo.
Check the hoses from the turbo to the intercooler in the front. It is common for the clamps to loosen up and the hoses to come off. It sounds like a pig squealing when it leaks boost.
TURBOCHARGER LEAK TEST
Check for loose connections or damage to air intake hoses and tubes.
Air leaks at the compressor manifold, intake manifold hose, charge air cooler (CAC) or intake manifold can cause excessive smoke, loss of engine power or a noise condition.
Exhaust leaks at the exhaust manifolds or in the turbine housing will also cause loss of engine power and a noise condition.
Inspect turbocharger and components for loose connections or damage. Using a liquid soap on hose or tube connections will aid in leak detection.
Exhaust leaks can usually be detected audibly or visually by a discoloration caused by escaping hot exhaust gases.
Jan 7, 2021 at 2:42 PM
