1993 Ford F350
1993 FORD F-350
DAWSONXX1
Brakes problem
1993 Ford F350 V8 Two Wheel Drive Automatic
replaced all brake parts front & back master 3 times booster twice have to when i crank truck up pedal goes to the floor can pump pedal for a little or let it sit & idle then i get a little pedal but i can also press down on pedal & push it to almost the floor but the truck will stop maybe its the abs valve dont know i have bled them many times & adjusted rear brakes they are new also
Dec 21, 2008 at 12:23 AM
