Brake Pedal goes to the floor
1989 FORD F-350
EBELL65
Brakes problem V8 Two Wheel Drive Automatic 275000 miles
I have a 1989 F350, 2 wheel drive dually, 460 ci gas motor. I have recently had the brakes done, front and rear pads, rear brake cylinders... The pedal has always been soft. I recently replaced the Master cylinder. I bench bled the MS before installing it. It appeared to be firm. I bled the wheels until no more air came out (went thru 4 bottles of brake fluid). The brake pedal goes right to the floor. Is there an ABS valve that needs to be bleed, if so where is it?
What else might lead to this condition. There are no leaks on the system. Everything is dry, but the pedal goes right to the floor with very little braking power.
Nov 23, 2008 at 9:50 PM
