2003 Ford F-250 Repair Question
Topics covered: Door, Door ajar light, Brake cleaner.
Asked on April 12, 2008
2003 Ford F250 Door Ajar
Crew Cab Lariat V10 Super Duty. The door ajar light and dome lights stay on all the time. A dealer had a computer hooked up to it and the computer says all 4 doors are shut while the door ajar light stays on. I have had the instrument panel, GEM, junction box and the driver door switch replaced with no result. Can you suggest where to look for the cause.
Answer
Replied on April 13, 2008
i usually find the problem to be the door ajar switch in the latch of the door that is least used. to repair it all i do is spray brake cleaner inside the latches to remove the dirt and oil then i spray the hell out of it with wd40 then open and close the door a million times. its either that or a wire rubbed through somewhere.
Spray the latches with a light lubricant such as wd-40.
